Scene fires three times??
(Sorry if this is a FAQ, but I can’t find anything in the docs.)
I have a scene that is being run three (3) times every time it’s triggered. How do I make the scene run only once?
Setup: UI5, veralite w/latest firmware, insteon devices run via altsteon.
I have a scene that is triggered via the opening of an insteon open/close sensor, which is connected to an exterior door. To make it easy for me to enable/disable the scene, I have the trigger set up to fire when the “device armed is triggered”; if I want to disable the scene, I simply disarm the sensor. However, making this slightly complicated is that I’m using Luup code to send me notifications, instead of the usual email. I’m basically using this to send notifications to my smartphone/tablet. If I test this using the “Run” button, everything works great. I get one and only one notification.
However, if I actually open the door, I get three (3) notifications, all in rapid-fire sequence. Is there any way for me to get only one notification, short of using global variables to prevent rapid-fire notifications?
Thanks.
