Hm… that was helpful.
Indeed, the Remotec runs the scenes when VERA is turned off.
Showing the problem. Some scenes stop after first (immediate) action. The following delayed actions do not come though.
Strikes me that these are lights being dimmed, maybe the Remotec cannot handle dimming in scenes…will have to check that
But I had this running before. …
So I hope that means that before, I had the scenes executed by VERA, being triggered by the Remotec.
So how to get there again ?
First exclude Remotec from network and remove all information from it.
Then restart:
From the discussions on the Remotec, all indicate that including it is performed by entering the code 8363 on the remote.
This is however specified to “replicate all network and device information” and I know by now it includes scenes.
The first time using this though, the Remotec gets included but no scenes have been made to be triggered by the Remotec.
It has to be there first obviously before it can be included in scenes.
Next scenes can be made, to be triggered by the Remotec buttons.
I include the triggers (button1,2,5,6,) in the scenes.
Yes!! , the buttons do work… to some extent. But button 5 and 6 are swapped and button 1 and 2 do the same as button 5 and 6…They don’t trigger the scenes that I made 1 and 2 a trigger for.
Problems with interference between scenes have been reported before but here entire scenes are swapped.
(http://forum.micasaverde.com/index.php/topic,8574.msg55090.html#msg55090)
I could do a new run entering code 8363 as others have suggested but that would replicate the network setting again and this time including the scenes, which I do NOT want.
Let VERA be the executioner of the scenes and the Remotec just the trigger.
What I did though, is put the Remotec in Listen mode by using code 8364 so that the Remotec could be configured.
The configuration was successful but after that I noticed no changes.
I tried using other buttons (7 and 8) for the scenes I miss but these buttons remain unresponsive on the Remotec.
Also after another Configuration run.
So:
It seems the problem is that the Remotec buttons do not trigger scenes as programmed.
I’ll probably stick to the PC, iPad or BB for running scenes.
