Uncaught TypeError: Cannot read property 'length' of undefined
but what you gave is a very partial console log so I cant see file / line number etc so cannot help much. can you please get me the exact ALTUI version number and a full console log more like an example attached ?
by the way you do not have to save several time the proper way would be
Click the wrench (spanner?) to edit scene
Click on Trigger to open the Device Triggers screen
Click the left side Check box to Disable my trigger 1 (of 2 on this scene)
The “Submit” box turns red at this point
DO NOT CLICK the Submit box , finish all your changes first
Click the Lua box to open Lua Edit screen
Type test Lua code – Test
Click Save Changes
Messages box at top of screen displays “Event Lua code edited, remember to save your changes”
Click the Submit box
Messages box at top of screen adds the “Edited Scene 40 Successfully” message to the “remember to save chnages” Line
“Edit Sucessful” line disappears, leaving only the “remember to save” line
Success message = green, they disappear automatically
Info message = Blue , they stick
After clicking on submit you have nothing else to do, it should be saved.
Now to really test, you can close ALTUI window and restart it and check your changes.
I do think you have a different issue but for that I need the exact console log with files & linenumbers
thx
None of my edits shows any entries into the log file. After the Submit box is clicked, I see nothing in the log, and the Vera3 lights don’t show anything.
the 2nd line in the log file is when I click to move on to the Device screen. I kept the log open, did a Luup restart, went back in and saw changes were not saved. I then went to UI7 and back to AltUI and did more scene changes, including adding a new device trigger, and still was not saved.
Please let me know if there is something else I can try?
Thanks again,
Mike[/quote]
you seem to have captured the “UI7” javascript logs, not ALTUI’s one
to make sure, close all windows, open altui in chrome, press ctrl+shif+J
Not sure you will like this one much better, but I do see one error, so maybe it will help. ???
I made 3 different edits to a scene, including adding a new trigger with a test Lua entry, and then hit Submit. None of that made any entries in the log. Maybe that’s why it doesn’t save?
Don’t know if it helps, but most times I do a Ctrl F5, it clears the screen and I get a brief message at the bottom left saying "waiting for 10.84.x.x Then I get a blank screen. If I wait about 30 seconds and do another Ctrl F5, I then see the AltUI Home screen.
Sorry to make this difficult, but appreciate any help you provide.
[quote=“ilikelife, post:6, topic:189304”]Not sure you will like this one much better, but I do see one error, so maybe it will help. ???
Sorry to make this difficult, but appreciate any help you provide.[/quote]
no that does not help unforunately. your files are not showing any error; the 500 internal server error is normal while Luup is restarting
what I need is the console where we can see the original error you reported
Uncaught TypeError: Cannot read property 'length' of undefined but with all the other lines before and after that
Let s also try another approach:
go to MISC DEBUG Javascript code and type this to send me the result
MultiBox.getSceneByAltuiID(“0-40”)
