Samsung S5
Does this work on an s5? I configured it, named my vera, and then i run the app. Once I get into the ap, and i say any command, the app crashes.
Have you reported the crash ?
Or the Debug Log ?
I turned on verbose logging.
Here’s a snippet:
note that I replaced my vera id with MYVERAID and my username with MYUSERNAME.
The strange thing is that PASSWORD appeared just like that, PASSWORD.
[code]Mar 10, 2015 10:26:47 AM V:VeraConnect.PersistLog:SetContext
Mar 10, 2015 10:26:47 AM I:HAL.VeraInterface:OnStartCommand
Mar 10, 2015 10:26:47 AM V:VeraConnect.VeraConnection:GetVeraIDs:UI5-MYVERAID
Mar 10, 2015 10:26:47 AM I:VeraConnect.Notify:Notification:Background Monitoring
Mar 10, 2015 10:26:47 AM I:HAL.VeraInterface:Run:Start
Mar 10, 2015 10:26:47 AM V:VeraConnect.VeraConnection:GetVeraAccess:UI5-MYVERAID
Mar 10, 2015 10:26:47 AM I:VeraConnect.NetworkListener:GetWIFIIPAddress:419430410
Mar 10, 2015 10:26:47 AM I:HAL.VeraInterface:OnReBind
Mar 10, 2015 10:26:47 AM I:VeraConnect.VeraGateway:URLConnection:/data_request?output_format=json&id=lu_status2&DataVersion=974870193&LoadTime=1425974870
Mar 10, 2015 10:26:47 AM E:VeraConnect.VeraGateway:URLConnection
Exception:java.net.MalformedURLException: Protocol not found: /data_request?output_format=json&id=lu_status2&DataVersion=974870193&LoadTime=1425974870
at java.net.URL.(URL.java:176)
at java.net.URL.(URL.java:125)
at com.rtsservices.veraconnect.access.h.b(Unknown Source)
at com.rtsservices.veraconnect.access.h.a(Unknown Source)
at com.rtsservices.veraconnect.access.e.a(Unknown Source)
at com.rtsservices.veraconnect.access.b.a(Unknown Source)
at com.rtsservices.veraconnect.access.e.b(Unknown Source)
at com.rtsservices.veraconnect.access.e.c(Unknown Source)
at com.rtsservices.hal.service.a.run(Unknown Source)
at java.lang.Thread.run(Thread.java:841)
Mar 10, 2015 10:26:47 AM I:VeraConnect.VeraGateway:URLRequest: No Response!
Mar 10, 2015 10:26:47 AM I:VeraConnect.LocalRemoteManager:URLRequest: Failed for Choice:-1
Mar 10, 2015 10:26:47 AM I:VeraConnect.VeraGateway:URLConnection:https://fwd3.mios.com/__MYUSER__/PASSWORD/__MYVERAID__/data_request?output_format=json&id=lu_status2&DataVersion=974870193&LoadTime=1425974870
Mar 10, 2015 10:26:49 AM I:VeraConnect.VeraGateway:URLConnection:https://fwd3.mios.com/__MYUSER__/PASSWORD/__MYVERAID__/data_request?output_format=json&id=user_data2
Mar 10, 2015 10:26:49 AM I:HAL.VeraInterface:ProcessUserData
Mar 10, 2015 10:26:49 AM I:HAL.VeraDataBase:New
Mar 10, 2015 10:26:49 AM V:HAL.VeraDataBase:Load:devices
Mar 10, 2015 10:26:49 AM V:HAL.VeraDataBase:Class:com.rtsservices.hal.vera.SecuritySensor:ArmCmd
Mar 10, 2015 10:26:49 AM V:HAL.VeraDataBase:Class:com.rtsservices.hal.vera.SecuritySensor:IgnoreCmd
Mar 10, 2015 10:26:49 AM V:HAL.VeraDataBase:Class:com.rtsservices.hal.vera.SecuritySensor:Status
Mar 10, 2015 10:26:49 AM V:HAL.VeraDataBase:Class:com.rtsservices.hal.vera.SecuritySensor:a
Mar 10, 2015 10:26:49 AM V:HAL.VeraDataBase:Class:com.rtsservices.hal.vera.SecuritySensor:b
Mar 10, 2015 10:26:49 AM V:HAL.VeraDataBase:Class:com.rtsservices.hal.vera.SecuritySensor:equals
Mar 10, 2015 10:26:49 AM V:HAL.VeraDataBase:Class:com.rtsservices.hal.vera.SecuritySensor:getClass
Mar 10, 2015 10:26:49 AM V:HAL.VeraDataBase:Class:com.rtsservices.hal.vera.SecuritySensor:hashCode
Mar 10, 2015 10:26:49 AM V:HAL.VeraDataBase:Class:com.rtsservices.hal.vera.SecuritySensor:notify
Mar 10, 2015 10:26:49 AM V:HAL.VeraDataBase:Class:com.rtsservices.hal.vera.SecuritySensor:notifyAll
Mar 10, 2015 10:26:49 AM V:HAL.VeraDataBase:Class:com.rtsservices.hal.vera.SecuritySensor:toString
Mar 10, 2015 10:26:49 AM V:HAL.VeraDataBase:Class:com.rtsservices.hal.vera.SecuritySensor:wait
Mar 10, 2015 10:26:49 AM E:HAL.VeraInterface:run
Exception:java.lang.NullPointerException
at com.rtsservices.hal.b.l.a(Unknown Source)
at com.rtsservices.hal.b.l.(Unknown Source)
at com.rtsservices.hal.service.a.a(Unknown Source)
Mar 10, 2015 10:26:57 AM I:HAL.VeraInterface:ProcessUserData
Mar 10, 2015 10:26:57 AM I:HAL.VeraDataBase:New[/code]
If it makes any difference, I don’t see a lot of the pages that are shown in the video at https://www.youtube.com/watch?v=_PVHOWRUGlA
So it seems I have the same problems as the posters at http://forum.micasaverde.com/index.php/topic,14608.90.html
My guess is the way that android restricts writing to sd card.
Latest release should fix these problems.
