I defined the same function in different scenes. Something like
function afterdelay (mystate)
local http = require("socket.http")
http.request("http://xx.xx.xx.xx/input4.php?State="..mystate)
luup.call_delay ("afterdelay", 0,0)
luup.call_delay ("afterdelay", 4,1)
So “afterdelay” is run two times after the scene gets activated.
Not on purpose I defined “afterdelay” also in an other scene luup code. Today I found out that under certain circumstances I cannot clearly define, one scenes triggers the function of another. I think that happens if both scenes are active. Did I missunderstand the concept? I thought the definition of a function in the luup section of a scene is only valid within that scene and only known to the system during runtime.
To my knowledge, each device has its own Lua context, so if you’d done that in a plugin’s implementation file you’d get the behaviour that you expected. Scenes, I think, all run from the _SceneController device (id = 2), so there may be some sharing of context in that case.
Or I could be totally wrong. I’ve read all the same documentation that you have, and you’ve done the experiment and I haven’t…
If the the scenes run under one virtual device, as you described, this behavior could be explained. It is however a very dangerous thing when you don’t know about it. Imagine having a big network with lots of automatic scenes. Its an obvious thing to reuse basic functionalities by copy and paste code of functions. So from now on I have to keep track somehow which function name I already used.
If the mechanism works reliably it could even be used to exchange data between running scenes!
