I noticed today that I cannot get into the vera UI through firefox anymore. A long running script error appears. It does work on IE. Oddly enough I also get a script error on IE from my Surface RT tablet. Is it possible that I’ve added too many devices and scenes?
Device counts are unlikely to produce script errors. The more likely cause is going to be a plugin that you added or possibly a change in the browser, though no one has reported anything like that.
Also, try clearing your browser’s cache.
[quote=“Z-Waver, post:2, topic:185725”]Device counts are unlikely to produce script errors. The more likely cause is going to be a plugin that you added or possibly a change in the browser, though no one has reported anything like that.
Also, try clearing your browser’s cache.[/quote]
I will see if there is a plugin added (none that I can recall). I doubt it is a browser change since the problem occurs across multiple devices.
