I cannot seem to find how to run a scene with lu_action over simple HTTP…
I used to use messagesend with id=360&28=<scene#> - what’s the corresponding way with Luup?
Thanks.
Thanks.
http://Vera_IP_adress:49451/data_request?id=lu_action&output_format=xml&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunScene&SceneNum=
Thanks! That did it.
I’m trying to have a scene on #1 Vera run a scene on #2 Vera that are on the same LAN network.
Is it possible?
How would that get written?
This returns “Error in Lua for scenes and events”
I do not want to bridge networks or add the other Vera as a UPnP devivce.
JOD.
Are you sure running the scene you are calling directly doesn’t have a problem with it’s lua code?
Scene 76 is on Vera #2. There is no code in that scene.
Running this code from a browser triggers scene 76. No problem there.
Adding this code in the Luup tab of a scene on Vera #1 returns the error.
http://192.170.1.4:49451/data_request?id=lu_action&output_format=xml&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunScene&SceneNum=76
Other than that code in a scene on Vera#1, that’s the setup.
JOD.
[tt]luup.inet.wget( , )[/tt]?
luup.inet.wget( http://192.170.1.4:49451, 5 )?/data_request?id=lu_action&output_format=xml&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunScene&SceneNum=76
luup.inet.wget( “http://192.170.1.4:49451, 5 )?/data_request?id=lu_action&output_format=xml&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunScene&SceneNum=76”
with & without http://
with & without 49451
JOD
[quote=“JOD, post:8, topic:164906”]luup.inet.wget( http://192.170.1.4:49451, 5 )?/data_request?id=lu_action&output_format=xml&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunScene&SceneNum=76
JOD[/quote]
luup.inet.wget( "http:/192.170.1.4:49451/data_request?id=lu_action&output_format=xml&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunScene&SceneNum=24", 5 )
No more “Error in Lua for scenes and events” But it still does not execute the scene.
I’ve tried with both ports 3480 & 49451.
JOD.
[quote=“JOD, post:10, topic:164906”]No more “Error in Lua for scenes and events” But it still does not execute the scene.
JOD.[/quote]
Did you notice I changed the scene number to 24 in the above. Worked for me, at least running from the lua panel in mios developers.
Did you notice I changed the scene number to 24 in the above. Worked for me, at least running from the lua panel in mios developers.Yes I did, and that you left the quotes in, I changed the scene number back to 76, but no go. It does get a "Message Sent Successful" when used in the sandbox, but does not run the scene.
This is what I’m using as a PC desktop shortcut for the same scene (which works)
C:\Users\Administrator\Downloads\wget.exe -q -O NUL "http://192.170.1.4:3480/data_request?id=lu_action&output_format=xml&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunScene&SceneNum=76"
JOD.
Does
luup.call_action("urn:micasaverde-com:serviceId:HomeAutomationGateway1","RunScene",{ SceneNum="0"}, 0 )
(adjust scene number and device id) work?
luup.inet.wget( "http:/192.170.1.4:49451/data_request?id=luup.call_action(“urn:micasaverde-com:serviceId:HomeAutomationGateway1”,“RunScene”,{ SceneNum=“76”}, 0 )
C:\Users\Administrator\Downloads\wget.exe -q -O NUL http://192.170.1.4:3480/data_request?id=luup.call_action(“urn:micasaverde-com:serviceId:HomeAutomationGateway1”,“RunScene”,{ SceneNum=“76”}, 0 )
Does not run.
JOD.
@JOD,
@Ap15e’s example should be paste as is into the Luup window. No additional wrappers are needed, and it wouldn’t include any [tt]luup.inet.wget[/tt] in that case either.
Similarly for @Automator.app’s recommendation:
ie. use this as is:
[tt]luup.inet.wget( “http:/192.170.1.4:49451/data_request?id=lu_action&output_format=xml&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunScene&SceneNum=24”, 5 )[/tt]
No removal of quote characters, and the only thing that would change is the [tt]SceneNum[/tt] value (24) to whatever scene number you’re using.
One “style” uses wget, the other style uses call_action
I’ll start again as I think there’s some confusion.
I’m trying to run scene #76 located on my Vera 2 at address 192.170.1.4
from a scene located on my Vera 1 at address 192.170.1.8
luup.inet.wget( "http:/192.170.1.4:49451/data_request?id=lu_action&output_format=xml&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunScene&SceneNum=76", 5 )Does not work.
JOD.
there’s a slash missing in the URL being requested.
It should be:
http://…
instead of:
http:/…
It’ll probably display the error in detail in the [tt]LuaUPnP.log[/tt] file, but would also “return” the status as a result of the [tt]luup.inet.wget[/tt] call, probably as a “[tt]400[/tt]” error.
;D That did it. Sigh…
Thanks guys. Big Time…
JOD.
*Edit. The working example.
luup.inet.wget( "http://192.170.1.4:49451/data_request?id=lu_action&output_format=xml&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunScene&SceneNum=76", 5 )
[quote=“guessed, post:17, topic:164906”]there’s a slash missing in the URL being requested.
It should be:
http://…
instead of:
http:/…
It’ll probably display the error in detail in the [tt]LuaUPnP.log[/tt] file, but would also “return” the status as a result of the [tt]luup.inet.wget[/tt] call, probably as a “[tt]400[/tt]” error.[/quote]
[quote=“JOD, post:18, topic:164906”]*Edit. The working example.
Thanks for this. It’s handy for running scenes on a bridged vera. The devices come through to the primary Vera, but not the scenes, so cheers. ![]()
Hello somebody!
I have a Door open plugin (Everespring) working with battery.
I’d like to writing this plugin battery level’s number in to the Virtual Thermostat (VST plugin) Cool_temperature setpoint
I make this scene, but not working
local battery_lul = luup.inet.wget (" http://192.168.1.101:3480/data_request?id=variableget&DeviceNum=79&serviceId=urn:micasaverde-com:serviceId:HaDevice1&Variable=BatteryLevel" )
Please HELP me!
