Hi Everyone,
Is there a way to detect a lua startup failure for a particular device?
I have a Denon receiver that works properly most of the time, but on occasion its network connection goes to lunch and the Denon plug-in starts reporting communications failures. Rebooting the receiver resolves the issue, so I put it on a Z-Wave outlet I can control through Vera. I’d like to detect a startup lua failure on the receiver and run a scene that cycles power on the Z-Wave outlet when a the startup failure is detected.
