RSS Feed Updater?
Was curious to see if anyone knew of a way to update an RSS feed based on output from a scene.
Example: Scene Space Heater - runs only when it is 8 PM and the temperature outside is below 48 degrees.
If the above example ran successfully I want to post to an RSS feed to state “Current Temperature is below 48 degrees. Space Heater has been turned on”. Does anyone know if this is possible with the HTTP Commands used in the following other threads or other options.
http://forum.micasaverde.com/index.php?topic=13619.0
http://forum.micasaverde.com/index.php?topic=13995.0
Thanks,
Bpavlica
no one nows how to do this?
