Hello,
My name is Michael and i am upgrading my homeautomation from Telldus Net 433MHz to Z-Wave and Vera3.
At the moment i am controlling my motorized 135" Roxcore cinema Projection screen with my Telldus Net stick.
I would like to control it via Vera with RFXCOM.
I asked RFXCOM support if the Roxcore scrren is supported and i got this answer:
[i]"Hi Michael,
The RFXtrx433 supports the Proluxx projection screen and the Kingpin. Both use a PT2262 protocol type. See chapter 9 in the RFXtrx User Guide.
The Roxcore has the same protocol type so it should be possible to control your screen. The only thing we have to know is which pulse timing is used.
The other question is does the VERA plug-in support the Lighting4 protocol?
It is not in the supported list: RFXtrx Gateway"
Can anyone answer this? As you already figured out, i’m no expert ![]()
Thank you in advance,
/Mike
