Hi all
I’m at my wits end with this one. Need some guidance.
I am using ui7, if relevant,Please reply with this in mind (as opposed to ui5). I have the latest firmware.
I have two categories of problems that may be related:
I have a couple of nodes that are flaky. I wake up and they are simply dead. Pings show no response. If I plug and unplug them they often come back. When they come back they have ping performance of 100ms with 10 out of 10 successful, so it’s clearly not a marginal signal.
I also have one node that typically only responds to 4 out of 10 pings and is generally always flaky. I can get “cannot contact device” or “error code 1” issues on occasion with these nodes as a result.
I have noticed that the neighbors are empty or just show “1” (scene controller) for these nodes. They aren’t directly close to the controller so this could be a problem. It seems like the mesh isn’t working.
What I’ve tried:
First, I’ve tried update neighbor nodes. I get “received empty reponse”. What’s up with that? Hen, nothing changes.
I’ve tried many reboots and many unpairs and re-pairs. No real change.
I’ve made a new service for ManualRouting and have entered nodes such as “45-1” where node 45 is directly half way between the problematic node and node that never has an issue. I’ve verified that it appears in the variables page as I’ve set it up. However, This does absolutely nothing, it seems to ignore this field. No change.
I’ve made sure there are no bogus device options set. In fact, no device options are set for any device.
I’ve tired to manually change the neighbor nodes in the advanced tab. Even if I click the check box and enter the field, it’s often later deleted by Vera. In any case, even when it sticks around, it has no change. No help.
I’ve played with automatically configure device off and on. No change.
I’ve tried configure mode now, etc…none of this does anything.
All nodes are within a 60 foot radius of the controller, there are a total of about 45 nodes now.
This should be an easy setup.
Any suggestions? Thanks so much.
