Router Rebooting on 1.1.1047 again?
I did submit a ticket on the issue, but was wondering:
Anyone notice if their Vera2 running UI4 release 1.1.1047 is rebooting itself randomly every 45-90min?
It hasn’t done that since UI4 1.1.1036 (I think… Whatever the first “official” UI4 was)
Thanks,
Frank
I have a Vara 1 and I am also experiencing random reboots. I also can not change the date. Keeps on reverting back to January no matter what month I put in. Some strange things are going on making my timed scenes activate at the wrong time. I wanted to telnet into Vera to force the date/time but I think that access is no longer available.
The date issue has been resolved and will be fixed in the next release (do not know when). The date issue is actually a cosmetic issue. When you pick your date and save, the correct date is set, but the drop down will show January.
As for random reboots. I have not experienced this issue.
  • Garrett
backed down to Firmware 1.1.1036 tonight. After more than 2 hours, the system seems stable (no reboots yet).
I also have issues setting the month. I can change to any month except August… When I try to “set” the time the month goes back to January. I’m just getting started but I think this is a bug. :-\
[quote=“garrettwp, post:3, topic:166437”]The date issue has been resolved and will be fixed in the next release (do not know when). The date issue is actually a cosmetic issue. When you pick your date and save, the correct date is set, but the drop down will show January.
  • Garrett[/quote]
I was remotely online with my Vera when it rebooted. It was 10:24am when this happened, when Vera came back online 2 minutes later it said it was 7:32PM and stated executing my night time scenes. Since this happened while I was online I sent a trouble ticket in with my logs. I hope that MCV has all the info they need to fix this.
I also have the issue of not been able to set August as a month. Using Vera 2 v 1.1.1047
Some scenes have been a bit random in working i.e not switching off. Could this be a result of vera re booting?
I’m having the same problems with my router rebooting and my scenes are VERY random in working.
Hi alfonsec,
At least we know whats going on now. Just need to find how to solve the re boots!!!
We found a temporary solution to stop the rebooting of the Vera box, for this please go to Advanced → Firmware and insert the next link into “URL for MiOS custom firmware:” text field
http://download.mios.com/backfirebetafirmware/wl500gP_Luup_ui4-1.1.1036-1.squashfs
and press the Download button and wait for the box to rewrite it’s firmware. After it is done please refresh the page pressing and holding CTRL key and press the F5 key in this time too. After this, your Vera box should act normally.
Be sure that this won’t be the final solution and we’ll work on the last firmware to solve this issue, but until that it looks like this is it… Please send us your feedback. Thank you.
@mcvvalyb, Are you an MCV employee?
I have been working with Ovidiu from MCV on this problem and this fix link is legitimate. It still needs to be tested. I’m not sure why the version number is lower than 1047?
Its odd as the latest unreleased beta is version 1.1.1062.
Also, somebody should amend the post above with the link to specify that this is a Vera2 version before somebody with a Vera1 tries it…I hope MCV has some protection in place to prevent the wrong version getting put between either box but you never know!
could you tell where is it possible to download version 1.1.1062
i cant found link for this release :frowning:
could you write it?
I’ve just tried the tip made by mcvvalyb and i’ll let you know how i get on. Hopefully no more reboots
Since adding this link ( http://download.mios.com/backfirebetafirmware/wl500gP_Luup_ui4-1.1.1036-1.squashfs ) 12hrs ago all has been running well, with no more rebooting!!!
8th September. All still working well since the change in firmware. No more rebooting and no more messed up scenes.
I just applied http://download.mios.com/backfirebetafirmware/wl500gP_Luup_ui4-1.1.1036-1.squashfs because I am having the rebooting errors. When I re-entered vera I got the message saying there was a later version available and I needed to update.
I am bock to 1.1.1047 now Bill
Hi bfuqua,
You will keep getting that message to upgrade because you are running an older version of the Vera Firmware, when you follow the instructions in this post.
I have stuck with the change as i’d soon get the upgrade message than have Vera rebooting all the time and messing up my scenes. Micasaverde say that the rebooting issue will be solved in the next upgrade of the firmware. Yippee :slight_smile:
I was having hourly reboots to with firmware 1.1.1047 and even with 1.1.1093. Went back to 1.1.1036 and this is working fine!
I’m seeing the same rebooting issues but am using a Vera 1. Can anyone confirm that this fix will work on Vera 1 as well?
Also, anyone have any idea how far out the next released firmware (that officially fixes this) might be?
