Rough weather
Without a weather plugin, Vera seems to “know” if it is raining. I think MCV does this when you enter your location. The Vera icon (upper right) next to the current temperature shows rain, or sunny. Is there any way to pull this from Vera using LUUP?
I guess I would prefer NOT to have the additional plugin (keep the destabilizing elements to a minimum) and just do a LUUP check and return (skipping the execution of the scene) is all I’m looking for.
There are some new API improvements coming soon from MCV for UI7.
The weather info maybe available at that time …
[quote=“RichardTSchaefer, post:2, topic:184722”]There are some new API improvements coming soon from MCV for UI7.
The weather info maybe available at that time …[/quote]
Good news, thank you!
