Having a long list of room created an issue, The list on the left side don’t have any scroll, so it’s difficult to reach the end of the list!
Also at the same time, the code box for some LUA under a scene edit, can’t be use when using Chrome on Android… you can delete code but can’t type anything…
[quote=“DesT, post:1, topic:194142”]I think I just found a little bug with the UI!
Also at the same time, the code box for some LUA under a scene edit, can’t be use when using Chrome on Android… you can delete code but can’t type anything…[/quote]
you can try to uncheck the option “Left Buttons are fixed on the page”
