I’m considering getting the RollerTrol controlled RF blinds, but according to the RFXtrx manual, all other protocols are disabled if BlindsT0 (the rollertrol protocol) is enabled.
I currently use RFXtrx with HomeEasy switches and KD101 smoke detectors.
Is there any way around this limitation?
Is anyone using Rollertrol blinds along with any other RFXtrx devices?
protocol enabling is only for receive mode.
You can transmit all commands including blindsT0 even if all protocols are disabled for receive mode.
What functionality is lost if receive mode is disabled?
Will I still be able to use Vera to open the blinds halfway through with receive disabled?
Yes, if you disable the BlindsT0 protocol (RollerTrol) you will still be able to transmit BlindsT0 commands with the VERA.
