RN 171 no receive echo message
'm trying to program the device RN 171 and I would like to figure out which command to use in order to avoid that in telnet mode after sending the first command displays the command you typed and then the result obtained by the command.
For clarity I describe as the telnet command and its result:
<4:00> show io
show io
0x8530
<4:00>
Let me know what to set in order to remove the writing from the form of repetition “show me” and get the following listing
<4:00> show io
0x8530
<4:00>
Are you sure you posted this on the correct forum? RN171 is a Microchip product. This is a Micasaverde forum.
[quote=“RexBeckett, post:2, topic:179983”]Are you sure you posted this on the correct forum? RN171 is a Microchip product. This is a Micasaverde forum.[/quote]It’s a Wifi <-> Serial adapter. A few of us here use them to adapt devices that need to go into remotish places…
It's a Wifi <-> Serial adapter. A few of us here use them to adapt devices that need to go into remotish places...
Oh [u]that[/u] RN-171.
@maurotafuro, have you tried entering the unset localecho command in your telnet client?
