I know that this is off topic, but I was wondering if anyone can help me on the RJ45 to RS232 pinout of the PowerMax Dual RS232 kit.
I am searching the internet for standard pinout but I can find couple of different options.
And I don’t know if PowerMax has a unique pinout or standard protocol.
Thank you for the fast replay.
I am trying to connect with the PowerMaster Remote program using a USB to RS232 cable from a Windows 8 Virtual machine, but with no luck. Is it something that has to be done on the Alarm side, or it should have worked?
I have tried every combination but without any success
The alarm system is a PowerMax Pro.
Nothing needs to be done at the alarm side. With the right connections and right RS232->USB (preferably an FTDI one) you should see communication. You can e.g. Use Doclight or other sw to check.
Thank you in advance.[/quote]
Why is this necesary? Is this the way to get the 3 modules working?
My Power Max Pro is equiped with GSM+RS232Dual+Powerlink and only 2 of them can work at the same time.
