I have the plugin pre beta 2, and firmware v67. Everything has been working fine for weeks. Had to unplug my vera a few times to include/exclude some door sensors. I plugged it back in, and now my rfxtrx device has a red error message lua startup failure, and on the top i have Rfxtrx:choose the serial port
This is the USB version i have. I have not touched anything which has anything to do with the rfxtrx
found it. No idea why and how this has been changed. But in Apps develop apps changed the serial port settings for rfxtrx to 38400, that did the trick
Hi Mike,
This happens to mine every so often. It’s usually when the RFX has been unplugged or when VERA has been rebooted a couple of times.
Just set the serial port values again, and it will be fine.
Thanks Mark, i got that sorted… but having to deal with a few other problems now. I thought i had it all under control… I am close to taking a hammer to my Aeon motion sensor (but not sure i can return it in little pieces so might refrain from doing that), the new Fibaro door sensor is not playing ball (just posted another thread on here about that)
So rfxtrx sorted, Aeon And Fibaro next…
