RFXtrx controller device
Hello,
I’m trying to use the module RFXtrx device controller for controlling the X10, but I’m not succeeding.
After reading quite a few forums about VERALITE , I already got that when I press the command (eg A2), the icon appears in VERALITE, but I can not change in the RFXtrx controller the state from ON to OFF or OFF to ON.
My RFXtrx is running :
Version pre-beta 2
Firmware:v70
Can you help me ?
Tks,
Victor Moreira
When you create your x10 device with the Rfxtrx device (in settings then scroll down to x10) that will create your x10 device, which you can then use to control your x10 device. The Rfxtrx device is only to create x10 and other devices, but you cannot use it to directly control your devices.
so how can I control the X10 directly?
with the device you create with the Rfxtrx device
Please Help Me,
post for exemple a picture …
I can?t understand .
sorry for my INCOMPETENCE .
Help me , Please :-[
Demanding help from your posts that are less than 24 hours apart from each other will not help. If anything will cause senior members of this forum to ignore your posts. It is considered rude.
  • Garrett
Do you have a X10 remote associated with your X10 device ? Your X10 device is a RF device ?
Normally, you push your ON button on the remote to power ON your switch. The plugin will automatically create a switch/power device in the Vera.
Then you can use the ON and OFF buttons on this Vera device to control your X10 device.
If you don’t have a remote associated to your X10 device, the process is just a little more difficult because you have to create your device manually using the settings tab of the RFXtrx controller device.
