rfxtrx and KAKU
I have a Vera3 and a rfxtrx transceiver. I can see Oregon modules But KAKU modules … there is a light module RFX Light L2.0/08ACCE2/01 but under control nothing and under device settings N/A So i can not switch the KAKU plugs on and off.
I assume you have reload the UI at least one time after the creation ?
Can you please check in the Advanced tab of the device the value of the attributes device_file and device_type ?
[quote=“lolodomo, post:2, topic:174719”]I assume you have reload the UI at least one time after the creation ?
Can you please check in the Advanced tab of the device the value of the attributes device_file and device_type ?[/quote]
device file D_BinaryLight1.xml device type urn:schemas-upnp-org:device:BinaryLight:1
BinaryLight1 is a standard device from Vera.
Is it identical for all you binary light devices, even those not created by the plugin ?
If you have no controls on these device, you might have to look for assistance directly to Micasaverde.
