RFXtrx and adding LightwaveRF Lights
Morning Guys.
I have a Micasaverde Vera, running Alpha10 version of RFXCOM plugin.
Vera box is all setup ready to go
In my living room i have a LWRF dimme switch and a PIR sensor. Both are paired successfully.
I was expecting the Vera box to automatically detect the LWRF devices based on a number of posts i have read, especially when the PIR is activated, acting as a remote. Unfortunately this does not happen.
I have tried to manually create the LWRF devices on the Vera box, using a Remote ID and Unit code of 1 and 1 and clicking on LWRF dimmer. This creates the device, but does not carry out any functionality. I can see that the RFXCOM is active as when i click on ON or OFF, the status LED flashes. The RFXCOM is in the same room as the LWRF switches.
Any advice at all? Thanks
No worries. Figured it out.
Once i have created the device in Vera, i then have to pair the devices up manually by putting the switch into pairing mode and activating the switch on Vera.
Is there a way i can have both the PIR and Vera control the switch.
For example, the PIR is set to the lowest LUX or i have a dusk sensor on the Vera. I can manually switch the light on through the Vera UI anytime of day, but in darkness, the PIR will sense me walking into the room and switch the light on?
As you had first imagined, if you have paired the PIR and the dimmer, normally the RFXtrx+Vera plugin should create automatically the device when the PIR sends a command to the switch. In other words, it is not necessary to create the device manually through the plugin.
So if it does not work, I need to know what is the message displayed in the Settings tab of the Vera device when the PIR sends a command to the dimmer. You can get the same information using the RFXtrx and the RFXmngr application on a PC.
As soon as I have this data information, I will be able to understand what’s wrong. At the same time, it will confirm that the RFXtrx is really receiving and decoding something.
Other hypothesis: the signal level of the PIR is too weak to be received by your RFXtrx. It could be true if your RFXtrx is in another room for example. I don’t know what is the signal strength used by LightwaveRF devices. RFXtrx receiving capability could be worst than sending capability.
