RFXSensor support?
Hi all,
I just got my Vera Light last week and have started to add devices to it. So far I like the Vera and especially this USB RFXtrx Transceiver Plugin. Thanks lolodomo and everyone else that has contributed.
I guess that RFXSensor device ( http://rfxcom.com/store/Sensors/40066 ) is not currently supported by the plugin so what can I do to make this happen? I am not good at programming anything but I will do what I can to help.
Best regards
Tomas
@lolodomo
How would you feel about if I would send you my RFXSensor to borrow for the purpose of making some kind of support for it in your plugin?
I know you probably have lots of other things on your plate to deal with but please let me know what you think.
I’m sure the guys at RFXCOM will also lend you a hand if needed (they have the best support I have come across).
Best regards,
Tomas
It looks like the RFXsensor is able to handle several kind of 1-wire sensors, some returning temperature, some returning voltage.
I could add support for temperature sensors. I add this to my TODO list.
Please try with the new file L_RFXtrx.lua file in the trunk ( trunk – RFXtrx Gateway ) and tell me if it works well.
:smiley:
Thanks! Trying it now!
Temperature sensors are all that I need. Ill let you know how it works…
Br
Tomas
So far Vera has picked up all sensors I have connected to the RFXSensor.
Also if I compare to my Homeseer setup all sensors have the correct value with even one more decimal then Homeseer is showing.
Thanks allot for making this happen lolodomo now I just need to figure out how to get a working wakeup-light event using an X10 dimmer ant then I can shut down my Homeseer system.
Br,
Tomas
