Is it possible to have more than 1 RFXCom connected to a vera ?
Yes it is possible, I am using a RFXtrx433 and a RFXtrx868 on a Vera Edge:
[url=http://forum.micasaverde.com/index.php/topic,38851.msg296129.html#msg296129]http://forum.micasaverde.com/index.php/topic,38851.msg296129.html#msg296129[/url]
Is it possible to change the device type when adding a new RFY device ?
I mean I have RTS Somfy blinds and I have also RTS Somfy lights. In that case, I would like just an ON/OFF swith. “Window covering” is the only choice in device type…
If yes, how to do ?
Also how to simplify the default control for device type (window covering) : I would like to remove the 0-100% cursor and open close buttons.
Thank you and merry Christmas !!!
