rfxcom lan Temperature not correct.
I have a Vera3 and the Rfxcom lan transceiver. I use the plugin rfxcom gateway, a few monds ago i used the rfxtrx and with the Oregon solar temp and hygro module i got ca 22 - 25c But now with the Rfxcom lan i get 40 degrees? i think theres something wrong with the plugin? Is there a possibility to change the actual degrees in the settings (i.e. minus 17c)
This is not the right place for the RFXLAN plugin. Please try ti ask your question in this topic dedicated to the plugin for the RFXLAN gateway.
Where do o find it? i have done a seach but i alway’s ended here!
http://forum.micasaverde.com/index.php/topic,4991.0.html
http://code.mios.com/trac/mios_rfxcom#
[/quote]
Tried this, with D_RFXCOM.xml but i get an empty box, i think there’s nobody with a rfxcom here.
People using a RFXLAN model are certainly not following this section of the forum as it is dedicated to the RFXtrx model.
Unfortunately for you, I see that you now asked help on the right place but with no answer. Maybe the development of the RFXLAN plugin has stopped, or involved people are no more present on the forum.
