I have previously developed an interface to an RFXCOM device.
With this device I can control HomeEasy or KAKU devices and receive messages from Oregon weather stations and operate Harrison curtain rails. The device supports many other protocols (X10, RFXmeter) for which I have no hardware to test…
Using luup I tried to develop a device to support this in Vera. But I have stumbled onto a problem. The RFXCOM device is connected to the network and has 2 separate ports for sending en receiving messages.
I thought I could develop a Primary device which creates 2 child devices, one for sending and one for receiving. But I found that did not work. It seems only the master device has support for network io.
How can I do this best? Should I create 2 separate devices, one for sending and one for receiving? And how can I best communicate between these two devices?
I’ve never tried it, so you’re going to be blazing a trail with this config. You may be able to use a combination of “attaching” the [Ethernet] for “reading” events to the Parent, and then writing specific Lua code inside (using LuaSocket) to “call out” to send the write events to the device.
If you do this, then you’ll at least get all the standard data events being delivered to you code, and have some of the Parsing stuff (cf, cflf, stx-etx, raw) to use, depending upon how the command responses are structured.
I wish you every success with this… please let me know if I can help with testing. I’m seriously considering purchasing a load of HomeEasy devices because they’re so much cheaper than the Z-Wave equivalents in the UK.
I already have a Vera2 with various other Z-wave devices. ;D
Reeferjon, unfortunately my time is sparse. I will post progress on this forum when I get something working…
But a word of warning about homeeasy is necessary. I have looked at pretty much all technologies available at the moment. I have an old house so I prefer those solutions which prevent me having to break open walls, ceilings and floors. Powerline communication and wireless communication are then the only two realistic technologies. I have a 3 phase power system in my house, meaning that I need a lot of extra hardware voor powerline comm and the speed of communication is very limited.
The wireless option seems more likely. I started with homeeasy because it is cheap and widely available. I also installed curtain rails with a wireless interface, both can be programmed through the rfxcom system. The good thing about rfxcom are the elaborate protocols they support.
But now the bad news. The protocol of the homeeasy and kaku devices is awfull. My primary issue is that it is very unreliable. You never know if a device will or has responded. When you press a button on a Homeeasy device it will send the command 4 times just to hope the signal will be received by an appliance. Terrible system, there is no way of knowing if a device received the signal.
If you ask my advice go with something else! It may seem cheap but it will always be expensive in the long run when you have to exchange all devices for something that works.
The reason I need an interface to rfxcom is because I like the exercise of programming… and I have a curtain rail that I want to send commands to…
The primary reason I started using vera is the possibility of combining multiple technologies. Enocean has the best sensors with energy harvesting, zwave has good actors for dimming and switching with good networking possiblities and homeeasy has some dirt cheap functions for simple things like opening curtains… And vera makes me use all of them together.
The code for decoding this message is in I_RFXCOM.xml. You might need to extend it for other Oregon devices. Or send me the raw data of the message and let me decode it for you.
The new RFXCOM is now xpl compatible. It will be great if Vera could support xpl: Vera could be use Oregon Scientifci Sensor, OWL, etc…
Do you think possible to use xpl on your plugin ?
I’m looking for a alarm system which can be linked to the Vera so I can use the alarm system sensors.
Is it possible with this plugin and the rfxcom LAN transceiver (with the 868.95MHz Visonic receiver) to use all Visonic Powermax Pro sensors with the vera?
I looked at xpl. Seems like another way of communicating. Not too complex. But a little bit beside the point to vera. Perhaps it is a good alternative to Vera?
I currently have too little time to work on this project.
The status of the rfxcom code is more of a starting point. It now only logs information from some devices. It needs to be expanded in order to control more devices. I currently use it to control a harrison curtain.
I’m new to the vera and luup development. My job is quite busy, but I have coding experiance with C/C++, C#. How hard is it to extend current implementation? At the start of the discussion you mentioned a problem with different ports for sending and receiving. Is this problem solved?
Before I will buy the powermax and rfxcom I wou ld like to know where I immerse myself in.
Vera is ok, but has its faults, stability is one, and platform support is the other. Lua is a very limited programming language and Luup has a limited programming model.
On the other hand Vera does the job best of all the hardware devices to control multiple systems that I have come across. Read also my website on the enocean technology, see www.esweb.nl.
Also the rfxcom platform has many limitations for the devices that I use (KAKU and Harrison). The support from the company is excellent.
Perhaps my best advice to you is to contact Bert at rfxcom and ask his advise for interfacing the powermax alarm system. I know they are working on support the xpl protocol. Perhaps you should take a look at that platform first.
The code that I developed is very rudimentary and needs a lot of work.
Is it complex? No. I too am a c# developer with a little experience at embedded development. And I managed to get quite far.
If you dare to take the challenge I would be glad to answer any questions you might have. I found the vera forum is quite active and your best bet to get answers from.
I’m new to luup/vera development, but last few days I have been working on the RFXCom interface. I can receive all my Visonic door switches and motion sensors. Currently I’m working on adding the keyfob using the activeRFID plugin. Using the keyfob all door and motion sensors are armed automatically. I have added klik aan klik uit (KAKU) so I can control these lights from my vera. KAKU is received in homeeasy format and Visonic as X10security so it should work on other equipment as well. I don’t have any other equipment (x10 / homeeasy / …) so I can’t test these myself.
I changed the RFXCom actually quite a lot and took some shortcuts. Because the RFX uses almost the same messages to send as received I actually just remove the ‘command’ part from the message and store the result as device ID. To send a message I only have to use the device ID and put the command in the right place. So I don’t do a lot of coding / decoding. This way you don’t have the official addresses/units, but it sure speeds up development :D. The kind of device is determined based on the message length (bits).
At this moment it’s still work in progress :-. I’m new in vera development so I still have to learn a lot and code can be improved by developers with more Vera/luup experience. If everything is stable I will update the SVN.
@evanes: I was wondering if you still used the harrison plugin?
Great to hear you working on the rfxcom interface.
I actually use the rfxcom only for controlling my harisson curtain rail. My next step was interface kaku buttons to receive commands and control other devices. I was having trouble finding a solution for a 4 button switch…
Currently I have no spare time to work on this project. Hopefully I will be able to in the future.
Cedric, as I mentioned before, the rfxcom interface already receives Oregon Scientific messages. But what do you think should happen with the Oregon Scientific message in Vera?
Should it be like a temperature gauge?
What vera/luup device type should it correspond to?
