There as a thread about how people have managed to get this device to only have local loads such that the switches control the loads without scenes, but can still be controlled remotely. Has anyone done this lately? I don’t want the scene controller capability of this; I just want 2 local loads that can be controlled without scenes (for better response and so I don’t have to tap the button twice to get it to turn on sometimes).
This is the thread to use. The performance issues that I had in the past were due to signal quality. The antenna in this switch is positioned such that it must receive a good quality signal at the front of the switch. Signal from behind the switch is blocked by the aluminum mounting plate. Signal from the side is not well received either.
Thanks; one of my switches is working great. The other 2 (4 loads total) require me to press the buttons twice to turn them on and once to turn them off. I’ll try re-including them to see if the behavior changes.
It looks like one of my VRCS2 is sending scene activate and scene deactivate events properly and toggles the light. However, another one sometimes sends scene activate and sometimes sends scene deactivate events requiring me to double tap the button to turn off the light. I know there was some comment about how Z-Wave scenes are not the same as Vera scenes which is probably the problem. However, I’m curious how one switch works and the other 2 don’t.
Also, I pushed and held the lower button of the VRCS2 and the top button cycled through load 1 on, load 2 on, load 1 & 2 on, load 1 & 2 off. Are there some magic options on this that are documented anywhere?
Assuming that you have them both configured in the same fashion, this is the sort of oddity that comes about when the switch has signal issues that result in different routes per switch.
It sounds stupid that the top button would have a different route than the bottom, but if you look at the Autoroute field you will almost certainly see that they are different. Improve your signal quality, or find a good route that you know will always be there and set it as a manual route.
I wasn't aware of that one. I got the same results when I tried it. To exit this strange mode I first tried the "Configure node right now" option on the Settings tab of each of the three devices to re-apply the Vera configuration to the switches. This didn't seem to work. After turning off the breaker for a few seconds, normal configured operation was restored.
Thanks for the ideas. The behavior is actually consistent. One tap turns it on; two taps turns it off (or vice versa, I can?t recall). The log shows that on the double tap, deactivate is getting called twice. So, the switch is sending messages, but the controller doesn?t know when a scene has been activated or deactivated. Could this be related to routes?
There is a 4 zone controller right next to this VRCS2 as well as a 1 button switch, so it has neighbors and everything seems to be working fine except for having to double tap to turn off the lights.
Too bad there isn?t a magic combination to simply make this device behave like many of us want; 2 simple switches.
(I?ve gotten so annoyed at it that I?m replacing 2 of these with 1 button Leviton switches; the second button was supposed to be for a scene, but I?m not going to play games in those 2 locations. Unfortunately I don?t have that luxury in 3 other locations.)
As one not to give up, I decided to give this mess another try. Here’s what I did to get the VRCS2 to basically control the local loads as well as be remotely controlled. I didn’t want to use scenes as I was getting a behavior where I had to double tap to turn off the light.
[ol][li]Factory reset the device[/li]
[li]Remove the local loads and controller from Vera (I waited until the job was finished on each)[/li]
[li]Put VRCS2 in programming mode (push both buttons at once until it blinks amber)[/li]
[li]On the Vera, Add Devices and choose custom. Select include @ Full Power. I put a long cable on my Vera and brought it close to the switch.[/li]
[li]Let Vera include the controller and 2 local loads.[/li]
[li]Rename controller and local loads so you know what they are.[/li]
[li]On the Vera, select the new controller and click on the Wrench icon.[/li]
[li]Click on Device Options.[/li]
[li]Add group ID 1 and select the first load. Click back to ZWave Optoons.[/li]
[li]Add group ID 2 and select the first load. Click back to ZWave Optoons.[/li]
[li]Close the settings.[/li]
[li]Click the Red save button.[/li]
[li]Flip breaker off and then on for the switch. My VRCS2 was still in a weird state where I had to double tap to turn off the lights.[/li][/ol]
After doing that, the buttons properly control the local loads. My first attempt at this, I went ahead and replaced the entire switch (I pulled 2 of these yesterday and replaced them with 1 button switches). I think the associations are key to getting rid of the double tap as well as being able to control the loads when the Vera is down.
I’m not sure what normally is for the LEDs, but they light up when the load is on (not very good for a locator light). Yes, I can cycle the switches on and immediately off with only two presses. I just tested it with 3 VRCS2 devices.
After testing this method myself, I think you may be on to something.
The buttons do switch the local loads and the LEDs respond appropriately, though not always instantly, even without Vera. Certainly it is faster/more responsive than activating scenes that then control the LEDs.
Associating a button with the local load and other devices also seems to work, at least for some devices. I have old Intermatic HA01 outlets that do not respond when associated to a button thereby requiring a scene. But other devices such as wall switches do work when associated to the button along with the local load.
Turning the breaker off and on again after configuration changes appears to be an essential step in the process. The switch does not behave properly or reliably until it is rebooted. I am now waiting to see if reconfiguration by a nightly heal impacts the switch(requiring a reboot) or not.
In my view, it’s really a 2-button scene controller, with two internal switches (like a VRCS4 is a 4-button scene controller with one internal switch); so the buttons are part of the scene controller.
The LED indicates the state of the scene, from the scene controller’s point of view (scene active = LED on). If the actual state of the switches is out-of-sync with the scene controller’s view (e.g. switch is on, but LED is off.), you’ll have to resort to the double-tap.
AFAIK, Vera is in the loop on this, and controls the LEDs; so a good Z-Wave connection between Vera and the VRCS2 is essential for proper LED behavior. Also, I find that the LED update commands from Vera are particularly prone to not being executed by the controller.
Associating the switches with the controller manually, is potentially not much different from having them programmed automatically by Vera through scene creation. I’m not sure if doing it manually takes Vera out of the loop, and thus results in correct switching and LED behavior, even with Vera powered off. Does this work?
Personally, we have these in our bathrooms, where one button controls the fan, the other button the fan light. Set up with scenes. This works.
We do get the occasional hang up (with other Leviton devices/controllers also), where a [tt]Configure now[/tt] (if the LEDs appear stuck), or a flip of the breaker (if nothing works), is necessary…
I completely understand that this is a scene controller with 2 local loads; unfortunately no one appears to make just a switch with 2 local loads. My problem with the scene controller part is that I was having to tap one of the buttons twice to make it turn off even if I had scenes that simply did a toggle.
So far, so good for me. A nightly heal ran and my switches still operate how I expect.
In any case, I hope this information helps someone.
I have confirmed that it does work, with Vera powered off.
If the switch maintains its configuration and doesn’t get flaky again, after a heal, this type of operation is preferable(to me) than the scene method that not only requires Vera, but also incurs a slight delay(even under the best circumstances) while the LED status is changed by the scene.
@sgruby - It appears to have been very helpful. Thank you.
Bah! If you operate the switch/local load from the Vera GUI, the LED does not respond at all. But worse still, my switch becomes unstable, requiring double taps to turn off and turning back on does not light the LED. I then have to reboot the switch at the breaker to restore operation as described earlier. Scenes update the LED as expected, of course.
I didn?t experience this; the lights responded instantly from the Vera UI and the LEDs came on (I really don?t care about the LEDs). Then I was able to use the buttons to toggle the local loads.
As for what I had before; I had tried both on and off scenes as well as toggle scenes.
I have no idea why I have all the luck on this one
I too have been struggling mightily to get my VRCS2 to operate in a usable way. @sgruby’s instructions do work and the switch behaves like a proper switch should: instant response. However, once I run a scene against the switch it becomes unstable again (requiring the double-tap to actuate), which is the same behaviour @Z-Waver reported after he tried the fix. Removing power from the device resets it and it works perfectly again.
No doubt there’s something that needs to be set/reset to resolve the issue, but I’m at a loss as to what or how to figure it out.
These are alternate ways of including / setting up / configuring the VRCS2, that folks have discovered, and retain (some of) the desired default functionality.
This is not the way the device is normally set up. Have you tried just including the VRCS2 and then setting up on/off scenes to program the buttons? (So without the manual associations and breaker cycle?)
With a good Z-Wave path between Vera and VRCS2, this should result in fast response times of the switches. The LED updates may be a bit slower (but that is probably ok; it is more important that they actually reflect the state of the scene, so you don’t need double-taps).
Including the device exactly as you described, and then after that never creating a scene in Vera triggered by one of the scene buttons, may be the key to luck.
