– store the retrieved data in Variable Container (this part works)
luup.variable_set(“urn:upnp-org:serviceId:VContainer1”,“Variable3”,WeatherCondition,22)
I have changed the dutchsmartmeter from one vera ui5 to the other machine ui7
Now i want to transfer the readings from one machine to the other to keep daily and monthly track of consumptions
For this i have made plugin which takes on a regulair bases the data from the smart meter into my app
For this i have made an I file
Now i want to get the info from the other vera and would like to incoperate this in the app
So if you can advice how to instruct this in the program i would be greatfull
If need be i can sent the file to you
Rgds
Huib
