Restrictions on Schlage Pin codes on more than 1 lock?
I have 2 Schlage door locks. When I enter pins, I select the choice to enter pin for both doors. Then I add date restrictions. Today, I checked to see if the pins were entered on the second lock. The new pins were there but the restrictions only show up on the 1st lock, where I initially entered the pin. Are the restrictions active for both locks but only show up on the lock where they were entered? OR Is this a programming oversight and will I have to enter the restrictions on both door locks separately? I am using application version: 1.7.2414
