How can I only restore z-wave network? I want to do a factory reset but don’t want to rebuild my z-wave network. I think the “Restore Z-Wave network” checkbox actually means “restore both”, not just the z-wave network.
Contact support. You are correct, restoring the Z-Wave network is a sub function of a full Vera restore.
The GUI does not provide a way of restoring only the Z-Wave network, but support should be able to do it manually.
Also, if you have additional Z-Wave controllers, like a hand held remote or a Z-Stick, you could reset Vera and then copy the Z-Wave network from the hand held controller.
I do have minimotes. I will try that before contacting support. Thanks!
