Howdy,
When I was first asking about PLEG and such, someone suggested that creating too many instance of a PLTS/PLEG could have negative impacts on vera, presumably in resource usage (RAM or CPU, I don’t remember anything being specific).
So I wanted to confirm/ask advice – is there resource usage/per-device consideration? Or are the devices just ‘faces’ to a common code base (so the incremental cost per PLEG/PLTS is just book-keeping overhead for that particular device).
If there is significant overhead for multiple PLTS/PLEG, are there any guidelines or ‘best practices’ to keep to (i.e. like ‘avoid more than 10 PLEG/PLTS devices’ or something)
While I understand a PLEG can be used for multiple things, I also am looking to create about PLTS units and while I can see a way to use a PLEG to do this instead of PLTS, I like the fact that the PLTS matches the intended use well and assuming there aren’t any resource issues, I’d prefer to go the ‘discrete device’ route. I’ll also have at least two PLEG devices as well.
Gerry
