resolved: Serious Problem with Remotec ZTS-100 thermostat
Homewave with the Remotec ZTS-100 tries to flip fahrenheit to celsius. In the process it sets the thermostat to the wrong temperature. I posted this problem to Homewave support page, but it sat in administartion approval for a few days, and then was apparently deleted.
I have a new, “vanilla” Vera lite setup. All I’ve done with the thermostat is pair it with the vera.
Do you have the settings for Homewave set to Fahrenheit or Celsius (Settings > Homewave > Temperature Unit)?
Thta’s probably it. I assumed it would take the thermostats setting. Thanks.
It should take the settings from Vera rather than the thermostat, not sure why it wouldn’t.
Also apologies for deleting the message from the support site; it must have been buried in the spam. The ration of spam to actual messages is like 50:1 or worse.
Correctly setting the temperature scale value in homewave fixes the error. Ideally home wave should complain about the mismatch rather than trying to set a fahrenheit thermostat to a celsius value. Alternately, homewave should not control a thermostat until C/F is explicitly set.
