My z-wave network got messed up. My vera 3 lost all the settings for the z-wave devices. I can reset all my door sensors and kwickset locks just fine. The outlets were added just fine originally but now since I no longer can exclude them I have no idea how to reset them. I took the thing apart thinking it would have some reset inside it and it does not. I tried holding the button down while powering it up and down twice thinking that might do the trick but alas no. Do I now have some overly priced regular outlets now?
That’s the thing they don’t show up as a device. I had a z-wave failed to start/no dongle found error and I had support fix the issue. After I restored from a backup none of my z-wave devices came back. My ip camera’s and elk M1 showed up fine
When you restored from backup, you overwrote whatever fixes MCV had made. You might need them to fix it again.
However, you may be able to fix it yourself. “z-wave failed to start/no dongle found error” typically means that you have the wrong setting for the port. Click Setup → Z-Wave settings and look at the port field. Usually, in the U.S., it should be /dev/ttyS0 See here for example.
Once Vera sees the Z-Wave dongle and can communicate via Z-Wave, then you can move to including or excluding a device.
It seems you might not understand the Exclude process. Deleting a device from the UI doesn’t exclude it. For the devices that were previously paired, you need to Exclude them first before they can be Included/Paired again.
It seems you might not understand the Exclude process. Deleting a device from the UI doesn’t exclude it. For the devices that were previously paired, you need to Exclude them first before they can be Included/Paired again.[/quote]
Thanks for that insight! I thought the Vera needed to see the device(s) before excluding it! I will try this later tonight.
I’m having an issue with a CA3500. I had a power outage the other week and it is just flashing red now and won’t be controlled by my MyNexia bridge anymore. I can’t find the instructions anywhere on how to include/exclude this device from my system. Can anyone tell me the procedure to put the CA3500 in pairing mode?
I can’t figure out for the life of me how to get this outlet into pairing mode. The setup guide says to look at the users manual, which is no where to be found. Any help?
The Activator button is also the Include/Exclude button.
Put Vera into Include mode and press the activator button.
If this does not work, it may already have been included into a Z-Wave network. In this case the receptacle will have to be excluded before it can be included. To exclude, put Vera into Exclude mode and press the activator button on the receptacle. Then include.
[quote=“sirwankel, post:13, topic:177210”]it’s new in the box, so I doubt it was included in a network. Should the light be flashing red or the red to blue?[/quote]It happens sometimes, even with new product. I don’t know what light you are referring to? Flashing red sounds bad.
