The third child does not update at all and I’m a bit stumped, tried re-adding it and setting various values in the device options but no matter what i do the third child does not update.
I’ve attached images of device options (default values) and how the devices look like.
Thank you for any tips in resolving this issue!
aPL
I had similar problems with mine and emailed Aeon support, had an email back in a few hours (US hour support I think) and suggested a few options. I would give them a go.
So what does that give for the 3 child devices.
I would hope to see total watts and kwh on the master with each phase watts and kwh shown on each child. This should show any lack of balance in usage of the phases.
parent - total watt and total kwh (sum of child 1+2+3)
Parents seems to be updated more often than children, I often see the parent update and the child updating after a few seconds.
There’s also the value 4144911 for param 101 - will also give you voltage and amps (i think). I’ve provided vera support logs and details to add support for these 2 values.
Did Vera give you any indication that they would support the Volts and Amps reporting ? I know (with my AEM G2 EU one phase) that with the proper settings an additional child device will be created and display V or A but with a “standard” labelling of W and KWH. Would be nice to have a proper display within the device.
Can you tell me those settings? I’d like to try them. Once I get a solid answer from them I’ll post here. But if you’d like that, make a request with support, the more people ask for something the faster it seems to get done (sometimes, at least)…
