now I want to clean my vera3 to really install in your final location…have a way to clean all devices added to my vera3 and come back to a clean vera 3 for me start a new installation ???
how the devices added will work if vera3 was clean ??
have I exclude the devices first one by one ???
You can easily remove the Z-Wave devices from Vera with one key stroke by performing a “Reset Z-Wave network” But, if your planning on using the same Z-Wave devices again, adding them back will require you to perform an exclude at each device first, so it’s probably better (IMO) to use Vera in exclude mode and walk around excluding devices one by one.
