I have a HA03 lamp module and a GE 45637 On/Off wall switch. Due to the wiring in my apartment I can’t wire it directly to an outlet that I need controlled, so I’ve basically set it up to physically turn nothing on/off… I’ve created two scenes that will trigger the HA03 to turn on or off accordingly. What I’m looking to do is have a way to reset the switch state to on/off if the HA03 is manually turned on/off.
So, let’s say the switch and the light are both off. I’m lying in bed and decide to kick on the light manually from my phone. Now the wall switch is off, and the HA03 is on. How can I get the wall switch to realize that the light is now on and reset itself accordingly?
Thanks!
PS. Does the verification go away after a certain number of posts or something?? Having to do 3 verifications every single time I post or reply is obnoxious…
Yes, verification is removed after so many posts. This has been brought up many times and a search would have answered this question.
There is no way for Vera to know if a switch has been manually turned on or off. Vera only knows if it is on or off with no distinction of being turned on from the switch or from the web UI. Also take into consideration that these devices do not support instant status and Vera would have to poll the each device to know their respective status. This can take some time (several minutes). Instant status informs Vera right away when a state of the device changes, so if you turn on a switch manually and the switch supports instant status, it will tell Vera of it’s change and this can be used reliably in a scene to take action. Since these devices do not support instant status, you will not be able to see the results that you are looking for.
In thinking about this it occurs to me that you could “fake it”, with questionable reliability, by using triggered scenes to control each device. The four scenes necessary would look like this:
Scene Trigger Action
Lamp On 45637 On HA03 On
Lamp Off 45637 Off HA03 Off
Switch On HA03 On 45637 On
Switch Off HA03 Off 45637 Off
But, having not tried this, I’m wondering is a loop would occur. Seems like it should work.
