Hi
I have a lot of Danfoss Living connect devices.
You great App, shows them as “?”, is it possible to get support for the temperature controll/status ?
Hope you can help… ![]()
/Cokeman
Hi
/Cokeman
Can you provide me your lu_sdata so I can look into it? You can retrieve the lu_sdata by going to the following link:
http://ip:3480/data_request?id=lu_sdata
Where ip is the vera ip address. Before you send it off, please go through the data and carefully remove any passwords or sensitive data you might have. You can take the data and put it into a json formatter found here: http://jsonformatter.curiousconcept.com/ to have the data be easily readable. You can than send the data to authomation at garrettpower dot com.
Hi
Hope you can figure it out… ???
It makes no sence to me… ;D
/Cokeman
Got your email, I’ll see what I can do. Can you tell me what the Vera UI device looks like for the Danfoss?
Hi
like this…
Hi
just got a hold of the beta 1.5.288, and now the I’m starting to get some information into your software
But I can see:
an temp icon, at “-1”
“cool” at -1
“Heat” showing the correct temp
“HVAC mode” = “auto”… Hmmm dont think that it can do that… LOL
“HVAC Fan” = “-” The same
and I do get a lot of “empty responces”…
/Cokeman
[quote=“cokeman, post:6, topic:170441”]Hi
But I can see:
“cool” at -1
/Cokeman[/quote]
Just to let you know that beta 1.5.288 is for beta users only. It is not meant for public use. Now with that out of the way, you are seeing that information, because the way I am parsing thermostats is for thermostats that contain all of those functions. I need to modify the code to help parse and only show what is needed for thermostats. Can you send me your lu_sdata again now that you are on 1.5.288 as it looks like data has changed for your thermostat with the beta.
sure, Beta’s ain’t for everyone… :
But Thats where I like to be…
Hope the new “dump” will help you…
Just a diffrent request…
I’m also using the “Variable Container” and “Virtual ON/OFF Switches”
Both are in the output you got early…
Can you get them to work also, then it will be perfect, for my needs ;D ;D ;D ;D ;D ;D
/Cokeman
Cokeman,
I did not get your updated lu_sdata. Can you send me the data again? I’ll see what I can do, but I can not guarantee anything.
Super.
Just left my gmail… ???
Hope you will get it this time…
-Cokeman
Still have not received it. I just replied to your first email to make sure you had the address correct. Not sure what is going on! Maybe a third time is a charm?
Hi
Well the address is the cached one, used for the first dump…
if it’s not in your spam, let me not, and i’ll ZIP the file, and ship it via my file transfer service, thats out of google and my home ![]()
Still nothing… Looks like google does not like the email
(using google apps for my domains).
Just tried again.
I have sendt you a link, where you kan download the .txt file i droped the output into…
Hope that works…
if not, I’ll send via the exchange server at work…
-Cokeman
Hi
did you ever get my output ?
Will it be easier, if you got a guest account on my vera ?
/cokeman
Cokeman,
Yes, I got the output. Funny thing is later last night I got three emails from you with the data. Not sure why it took some time to get to me.
I looked over your output real quick and it contains some more data I can use for the Danfoss. I’ll try and add the support in the next version.
Sounds great… ![]()
Let me know if there is anything I can do (e.g. guest access to my device etc…)
-Cokeman
