I’ve been scanning the wiki and the forum for information on Vera’s z-Wave routing and while there are a number off interesting posts one that stood out was the post on the wiki about debugging that pointed to you being able to see the routing performance via the ‘AutoRoute’ variable - however I can not see that variable listed on the UI (no is doesn’t seem to be hidden)
Unless I’m mistaken (I probably am) there should be a service call “urn:micasaverde-com:serviceId:ZWaveDevice1” and a variable called AutoRoute and another one called ManualRoute that I could extract
So I wanted to start off by extracting the AutoRoute variable values to an external file, but I think because they cannot be found it won’t work.
local devID = 122
local autoroute = luup.variable_get("urn:micasaverde-com:serviceId:ZWaveDevice1", "AutoRoute",devID)
local filename = '/nas/xyz.txt'
local outf = io.open(filename, 'a')
outf:write(os.date('%Y-%m-%d %H:%M:%S '..os.time()..'\n'))
outf:write("This is a the routing performance of the Everspring plug socket.")
outf:write(autoroute .. "\n")
outf:close()
Stupidly after running it via the http api I realised I had been using the wrong DeviceID - doh!
I saw some code from @Ap15e and would appreciate some help to use it to modify my script above so it will list all my z-wave devices and their auto route values.
[code]
– Vera - Dead Battery Devices
– local filename = ‘/etc/cmh/dead_devices.log’
if tonumber(string.match(Capabilities,‘([%d]*),’)) < 128
then
WakeupInterval = luup.variable_get('urn:micasaverde-com:serviceId:ZWaveDevice1','WakeupInterval', v.udn)
LastWakeup = luup.variable_get('urn:micasaverde-com:serviceId:ZWaveDevice1','LastWakeup', v.udn)
if (WakeupInterval ~= nil) and (LastWakeup ~= nil)
then
age = os.time() - tonumber(LastWakeup)
if age > tonumber(WakeupInterval)
then
outf:write(v.description..' is dead for '..math.floor(age/3600+0.5)..
' hour(s), WakeupInterval is '..WakeupInterval..' seconds\n')
for k,v in pairs(luup.devices) do
if (v.device_num_parent == 1) and (not v.invisible) then
autoroute = luup.variable_get(“urn:micasaverde-com:serviceId:ZWaveDevice1”, “AutoRoute”,v.udn)
if autoroute ~= nil then outf:write(v.description … ’ has this route and performance ’ … autoroute … “\n”) end
autoroute = luup.variable_get(“urn:micasaverde-com:serviceId:ZWaveDevice1”, “AutoRoute”,v.udn) or “”
outf:write("Node: " … v.id … " Name: " … v.description … " has this route and performance: " … autoroute … “\n”)
it’s strange that not all z-wave devices report their autoroute values/performance. They all have neighbours listed, so I wonder why they do not show their routing performing - any ideas?
Also it would be pretty cool if this info could be more visually represented, so it could show people how their mesh network is performing and which routes are good and bad etc.
it's strange that not all z-wave devices report their autoroute values/performance. They all have neighbours listed, so I wonder why they do not show their routing performing - any ideas?
Those of mine that have no [i]autoroute[/i] values are all battery-operated devices. Presumably they didn't respond during the heal process.
Based on the results from my network, I wouldn't use it for any sort of guidance. Most of my devices show that all routes fail - despite working just fine. This includes one that is just three metres of open air from Vera. Go figure...
Yes, it would be really helpful if MCV would describe the contributors to marking a route as bad (i.e. [tt]x[/tt]'ing it out); it somehow seems ‘trigger happy’.
