Hello,
I am new to z-wave and was hoping someone would have this question.
I have regular wall toggle switches controlling an outdoor water fall.
I wanted this to be controlled by zwave
what benefit or disadvantage would this have over just replacing with a single pole z wave switch and throw the old toggle away
if I used the above aeon product, if this was turned off remotely through vera lite, i can’t see how it would trigger the toggle to physically go ?p or down to correctly signal the state to someone looking at the switch. Am I thinking about this right?
The microswitch would allow you to use your existing switch if you did not want to replace it (mainly just for looks reasons). The switch does not physically get moved. The microswitch has full control of the power of the power source. The existing switch (your toggle switch in this case) is only used to activate the microswitch to tell it to turn on or off the power source.
Garrett, Thank you for your response. As I see it this would be the sequence of events using the micro switch:
The item is ON with the toggle in the up(on) position
A scene gets triggered and the microswitch is turned off remotely by vera lite but the switch physically stays ON but the controlled item turns off
a user physically will need to pull the switch down, which does nothing, and then switch back up again to yet again turn on the item?
4)OR, once the item is functionally off, regardless of the position of the physical switch, any change in the switch will turn on the opposite state?
-one more question. For the regular zwave single pole wall switches that have an off and on physical position, will remote change by vera-lite also change the position of that switch to reflect the OFF and ON state?
[quote=“Darthvuder, post:3, topic:175616”]Garrett, Thank you for your response. As I see it this would be the sequence of events using the micro switch:
The item is ON with the toggle in the up(on) position[/quote]
Correct.
Correct.
I believe in what ever state the microswitch is in, when you move the toggle switch to the opposite position that it is in, it will either trigger an on or off. So if the microswitch is in the on state, and the toggle switch is in the off state, moving the toggle switch to on will tell the microswitch to turn off. Not position, have a look at the manual.
See answer to question 3. The manual may have more details. Think similar to a 3 way or 4 way switch setup. Where the other switch is in the opposite direction of the other switch depending on which was turned on or off.
The Leviton switches do not have a physical paddle type switch. It is a momentary type switch where you press the bottom of the switch to turn on or off the light. The switch is meant to look like a paddle switch. The GE and Evolv switches are similar. They have a top and bottom switch that acts like a momentary switch where you press the button. They do not physically change position.
Garrett
