Replacement for the Wayne Dalton HA-14 3-way switch
Is there replacement for the HA-14 3-way switch?
All switches I found so far require an auxiliary switch. HA-14 was not very reliable, but it worked with the simple switch and didn’t require connection to neutral.
[quote=“virginian, post:1, topic:177589”]Is there replacement for the HA-14 3-way switch?
All switches I fount so far require an auxiliary switch. HA-14 was not very reliable, but it worked with the simple switch and didn’t require connection to neutral.[/quote]
No. The closest option would be the Aeon Labs In-wall Micro Switch or the Fibaro equivalent.
Yes. The CA600, also made by Intermatic, is pretty much a drop in replacement for the HA14. There are a couple of different jumper methods on the standard switch at the end, but they all seem to work. I posted about this last year.
Check either Ebay or AutomatedOutlet for prices. Please note that this is also a discontinued product.
[quote=“kkl, post:3, topic:177589”][quote=“virginian, post:1, topic:177589”]Is there replacement for the HA-14 3-way switch?
Check either Ebay or AutomatedOutlet for prices. Please note that this is also a discontinued product.[/quote]
kkl,
Thank you, ordered one form the AutomatedOutlet.
Installed CA600, works like a charm.
CA600 has an interesting feature, small led on the front panel is flashing indicating that switch is not a part of the Zwave network. Flashing stops after adding device to your network.
