Replace floor sensor
I have a underfloor heating with underfloor sensor - it has its own controller however the sensor has broken (reads 45 degrees at all times ) The controller controls an integrated mains (240V) relay so I need to replace everything
If I just leave the unit on - it heats up but not so much that its a hazard , however I dont want to rely on the Vera
so I would like the set a temperature say 24C and then a timer control saying heat to the set temperature (say 6:00 to 7:00 and 20:00 to 22:00 )
The Vera would be only to say I’m home/away and summer/winter type control
Can anyone suggest anything appropriate - I think a Aeotec temperature Zwave sensor could be mounted close enough to the floor to sense close enough to the floor temp
