What would be source for the below message appearing every 5 sec.? Is this a normal behaviour? I sometimes have delays in the response, wondering whether this could be the source
Those requests are from AltUI and used to update the display state. You’ll see that the requests have both a minimum time (milliseconds) to wait before responding, and a maximum timeout (in seconds.). Normal behaviour is that there won’t be a response until something in the system has changed. In your case, this seems to be every five seconds or so.
These delays are managed asynchronously by the scheduler and don’t block the normal operation of plugins, etc.
Thanks for the info. I"ll have a look at the devices. I use some countdown timers but they should not be active all the time, every 5 sec seems too fast.
That’s highly likely. I need to update VeraBridge to also run asynchronously, using the same method with its remote Vera. However, at the moment, it does indeed poll every 5 seconds. But it may be possible to stop it forcing an openLuup update if nothing has changed remotely. I’ll take a look.
Spot on, in fact. It seems that VeraBridge was updating its own LastUpdate variable on every 5-second poll. I’ve changed it to only update if a remote variable has changed, and put the fix in the testing branch.
If you update openLuup from the plugins page with testing in the Update box then you should pick up the latest. Would be very grateful of a report on how this goes.
