I’m discovering PLEG, and I want to use it to control the shutters in case of high temperature outside, I have put multiple conditions.
I asked to close the shutter at 20% in the living room, only under the following conditions :
- Outside temperature >= 25
- Door of the living room is closed
- Shutter are over 30% opened
- Only between 2 and 6pm.
here is the condition : pExTemp >= 25 AND sAfternoon AND pLivingDoorOpen == 0 AND pShutter_position >= 30
It works exactly as expected, however if for any reason I want to open the shutter manually, it remains closed and I have to bypass PLEG…
Question is, how can I tell PLEG to fire only once every 2 hours for example ?
Thanks for your help.
Kris
