Renumbering devices
Is there a way to renumber devices?
Due to ‘ghost’ devices auto-created in the past by the RFX433, devices deleted due to issues, duplicates etc the numeric device level reached far exceeds the number of devices attached. There are now large gaps in the sequence. It would be really useful to use this headroom rather than run out of device numbers if this continues. Is there a programmatic or a manual way to do this without doing a full reset and recreating from scratch?
I am running Vera3 with the latest version of UI7
No, you cannot renumber devices.
You will not run out of device numbers. Vera device numbers count up to at least 65,535 and possibly higher than that. I’ve never tried to find the limit. Z-Wave node numbers that reach the 232 limit will wrap and start re-using lower available numbers.
