Hi
Some of my sensors have been wiped out by a re-configuration. How do I remove them from Graphs and Whisper?
Cheers
C
Hi
Cheers
C
OK got rid of the graphs. How can I unwatch a non-existent sensor?
Cheers
C
Described on page 19 of the documentation manual…
A second command nowatch stops logging of a specific variable:
http://<yourVeraIP>:3480/data_request?id=lr_DataWatcher&nowatch=321.urn:upnp-org:serviceId:Temperature- Sensor1.CurrentTemperature
This is useful to deselect unwanted devices picked up when using wildcard device numbers, particularly if being used interactively.
Thanks, I searched a lot of things in the manual but missed that! Appreciate it
C
HI
I tried this, but the item is still visible in the Whisper section. What am I doing wrong?
Just checking the Whisper files, there’s been no update to them for 5 days (not surprising) could I simply delete them from the folder and expect them to vanish from the Whisper web page?
Cheers!
C
Cheers
C
Yes indeed. Unwatching doesn’t remove the file… you may choose to start watching again.
