Removing Global Condition from Start
Firstly I’m a new user to Vera and ALTUI. I loving ALTUI and the way in which you can see the live progress of through the Workflow.
However I went into Start and set a Global Condition but now I cannot remove it as it says ‘Transition appears to be empty’, is there any way to remove this Global Condition without deleting the entire workflow and starting again?
Simon
I’ve just noticed that I can probably use the Workflow Editor but which sections do I remove/edit?
Probably a bug but need to be back at home to address it , in acouple weeks
Just delete your Global Condition and add a Timer for 0 sec.
That sorted it, thanks :slight_smile:
