Removing Aeon Labs DSC06106 from "All Off"
We have a GE 45600 remote that we use to shut everything down with the “All Off” function, which works great except I have an Aeon DSC06106 hooked up to our washing machine that also responds to that command (it’s a global command, so it makes sense). I know for the other GE switches you can exclude from All Off from the remote, but that process doesn’t seem to work with the Aeon swtich. I also know that for the GE switches you can set the variables directly from Vera for it to not respond to All Off, so i’m hoping it can be done the same way but I can’t find any documentation or posts with regards to that.
I know I can create a scene and do it that way, but the wife has the All Off method down so i’d like to avoid changing that routine if at all possible
See this thread:
http://forum.micasaverde.com/index.php/topic,33300.0.html
