Removing a luup file?
I tried to change the code for a battery device so that the device would show the battery level as a number. Worked fine, but now I have two D_ComboDevice1.json files under Luup files. I thought that uploading a new one would the replace the old one.
How do I remove the old file?
There’s the shipped directory (/etc/cmh-lu) and the user-specific directory (/etc/cmh-ludl).
Vera will use the user-specific copy of a file, if present, and it automatically overrides the shipped directory. The UI, however, isn’t particularly smart in that it shows both but with no disambiguation between the two.
There is no need to delete anything in this case, it’s just a UI bug.
