I took the upgrade offer, but instead of returning my unit I’ve passed it onto a friend so he can start using VERA2
It’s still under my login, how can I disasociate myself from the VERA2 so he has full control
Tried a factory reset on the unit but it’s obviously account related and I can’t see where to do it anywhere
Please do a search. This has been asked many times in the last month or two.
searching for remove vera returns no results
thanks for your help
I found 6 threads asking this question with “remove vera”.
Here is one for starters:
http://forum.micasaverde.com/index.php?topic=9945.0
[quote=“richskiddle, post:3, topic:172849”]searching for remove vera returns no results
thanks for your help[/quote]
Edit: never mind
My search can’t be working then. See enclosed
But thanks for the link, I will give it a try
How can I goto http://veraIP/cgi-bin/cmh/remove_ra.sh if it’s no longer plugged into my network?
Try having your friend issue the link.
Looks like you had a topic open in General/General, then did a search using the search box; which yielded no hits in that topic?
