HI there,
I currently have a scene which activates a playlist in a bedroom. However, if the bedroom has previously been selected in a group, the playlist gets pumped through all those additional rooms. How do I check and then unselect any other rooms before the playlist plays?
Many thanks
Normally it should not be a problem if your bedroom zone is not the coordinator of the group.
If it is, you have probably to switch the coordinator first, there are upnp calls for that but I don’t know how to call them.
Or setting URI to any member of a group makes it become the coordinator of a group ?
BecomeCoordinatorOfStandaloneGroup has to be called first when you want to exit a zone from a group. If the zone was the coordinator of a group, the coordination will be translated automatically to another zone.
