I added a couple of New Services under Advanced settings for my thermostat in a vain attempt to get my Vera to recognize an outdoor temperature sensor connected to it. Is there any way to remove those entries now? They don’t appear to be causing any trouble, but I was just curious.
As of right now, you would need to modify the user_data2.json file manually and upload it back into vera if you want to remove a variable from a device. Not for the faint of heart. There is also a thread around here that had lua code that you could modify to remove a variable. In the end, if it is not hearting anything, I would just leave it alone. I also believe that Vera does not support reading the multiple sensors in the tstat.
- Garrett
